Spiderman Coaster
The Guru
The Guru
Spiderman face carved from HDPE from Inventables.
Two-Color HDPE - White on Red
Thickness: 1/4 in, Dimensions: 12 in × 12 in, Quantity: 1
$9.97
$9.97
spiderman-face2.svg
Source SVG file
spiderman-face4.cb
CamBam file for milling
Load HDPE into Shapeoko
2 minutes
Home Shapeoko
Move Shapeoko into home position over corner of material
Load code
Load gcode into UGS or appropriate controller
Send!
Send the file to the machine.
Dan Pearl III
Bit type, speed and fed rate? I am very new at this and still learning. Thanks
Dan Pearl III
The Guru
Hi Dan - DOC = 0.05" Feedrate = 30ipm Plunge = 10ipm Stepover = 35% Tool Diameter = 0.0625 Stock Dremel w/SO2. Speed = 8-10. You can definitely go faster on an X-Carve. I used a 0 helix bit - works best with HDPE. Best of luck.
The Guru
Dan Pearl III
Could you send me a link showing the 0.0625 Stock Dremel w/SO2.
Dan Pearl III
The Guru
Dan - what do you mean a "link showing the 0.0625 Stock Dremel"?
The Guru
The Guru
Ah, I think I understand. 0.0625 is the width of the bit; stock SO2 is just that - an unmodified ShapeOko2 with the stock dremel. Any X-Carve should work - you will need to experiment with speeds and feeds though.
The Guru
