The process that I follow, is to edit the FILL shapes with the correct lettering and arrangement (being careful that I maintain the 'split' in the middle.
Then, when happy, select all objects (CTRL A), combine them (CTRL J) and finally, change it to an OUTLINE, rather than a fill.
The process that I follow, is to edit the FILL shapes with the correct lettering and arrangement (being careful that I maintain the 'split' in the middle. Then, when happy, select all objects (CTRL A), combine them (CTRL J) and finally, change it to an OUTLINE, rather than a fill.
Sean Anderson
Hello sir I was wanting to know if I could use this file to create a monogram I making one for a lady at my church but she wanted a circle around it I am new to X carve
Rob Vittitoe
Rob, yes, help yourself.
Sean Anderson
So how would I use this for a different letter?
Tyler desper
