** The author's moral rights;
Hi ! I love the stamp with rocket on one of your picture ! Do you have any SVG file of it ? Will be nice to make one !
Patrick · September 05, 2017
What do you recommend to clean the stamp with? Obviously the material is MDF so you can’t use water or you’ll ruin it
Kayla Cooper · December 27, 2018
Use Rubbing Alcohol, that should do the trick!
Venessa Persaud · February 19, 2021
