Steve's 4" Blast Gates
135 opens
67 copies
2 comments
Steve Moloney
Steve Moloney
4" blast gates. Use sewer line PVC and fittings.
I cut a coupling in half so you only need one per blast gate.
To go to the standard dust collector fittings . Line the inside of the coupling with a piece of the 4" pipe then the standard couplings will fit in perfect.
Pieces and parts
1/2" MDF 3/8' Dowel 2 @ 1" 3/8" Dowel 1 @ 4" 1/4" - 20 x 5/16" Pronged T-Nut 1/4" x 2' Bolt 1/4" Washer 4" Sewer and Drain Coupling. 2 rings cut from it at 1-1/2" 1/4" drill Bit 19/64" drill bit for T-nut 3/8" drill bit
Phillip lunsford
Thank you Steve. This blast gate is excellent.
Phillip lunsford
Andrew Sander
Made a bunch of these for my parents new woodshop space. They work great with no leaks. Thanks Steve!
Andrew Sander
