Studded Trivet
1736 opens
479 copies
4 comments
Sam Alaimo
Sam Alaimo
Corian is a great material for trivets!
Black Corian®
Black Corian®
Thickness: 1/2 in, Dimensions: 8 in × 12 in, Cut Tolerance: +/- 1/8 in
$76.54
Add to Cart
$76.54
Engrave
This project has one workpiece for engraving with a v-bit, and a second workpiece with the cutout.
Engrave the first workpiece using a v-bit and Easel pro.
cut out
Click over to the second workpiece and change the bit to a flat bit.
Then cut out the engraving.
Sand
You might need to lightly sand the deep parts of the engraving, then you are good to go!
Brett A DiSario
I am cutting one of these out of MDF just as a sample. It is working great. But I'm finding out ,as it is doing the vertical lines, the machine doesn't have a lot of downward stability as it crosses the horizontal lines.
Brett A DiSario
Brett A DiSario
Did you come across this issue also? Maybe you can change your program to do all of the first step cuts. Then all of the second step cuts. Then the third. It would also cut down on your run time. And possibly make more define cuts
Brett A DiSario
Brett A DiSario
I am planning on making Trivets for a family member for Christmas this year. More of a 3D tree design.
Brett A DiSario
Tim Behm
Can you download a DXF to be used on Easel
Tim Behm
