T-Shirt Folding Board
0 opens
0 copies
528 downloads 1 comment
Lawton S
Lawton S
Alaska
With three simple flips, you can get wrinkle free clothing ready in no time! Shown in the Big Bang Theory TV show, this convenient T-shirt folding board can save precious time and space. The design can be cut in under an hour, and uses bearings for smooth motion and tight tolerances.
MDF Wood
MDF Wood (×4)
Dimensions: 12 in × 24 in, Thickness: 1/2 in
$40.00
Sealed Bearing - 3mm x 10mm x 4mm
Sealed Bearing - 3mm x 10mm x 4mm (×6)
ID: 3 mm, OD: 10 mm, Thickness: 4 mm, Type: 623-2RS
$40.00
Right.svg
Vector image of right tab
Left.svg
Vector image of left tab
Center.svg
Vector image of center of board
Bottom.svg
Vector image of bottom tab
Carve the Boards
51 minutes
To begin, carve the design found on Easel. If you purchased 12″ × 24″ MDF wood from Inventables, you will need to carve each of the four workpieces on a separate boards. Otherwise, you can use the fifth workpiece, which carves everything on one board. The carving takes about 50 minutes.
Drill Bearing Holes
Once you’re carve is complete, locate the center board (the one with six pegs sticking out). From the peg, mark a point half an inch from the board and half way down (1/4 inch). Drill through the hole using a 10 mm or 25/64 in drill bit. Alternatively, you can use a 3/8 inch drill bit. Repeat this for all six pegs.
Drill Screw Holes
On the other three boards, mark a point again half an inch from the board, and 1/4 inch from the top. This time, using a 1/8" drill bit. Repeat this for the other pegs on all three boards.
Install Bearings
Next, press a bearing into each of the six pegs on the center board. Those using drill bits from the imperial system will find that sanding will be necessary to get the bearing in (especially if you went with a 3/8" drill bit).
Assemble Joints
Finally, align the boards so the inside of the bearing aligns with the holes you drilled on the other three boards. Insert a 3mm diameter screw through the hole, and attach a nut to the other side. Do this for all six joints.
