Tic tac toe on the go
1046 opens
471 copies
6 comments
Rex Hickey
Rex Hickey
This tic tac toe board and its pieces can be cut out in 43 minutes using the provided settings.
I designed this so people of all ages could experience an age old game in a new way.
Soft Maple - Hardwood Type
Mark Cooper
Can you make this project available to public. Currently it is not. Thanks for your consideration. Great job!!!
Mark Cooper
Rex Hickey
I will! I must have messed up along the way because I thought I had it public. Sorry for any inconvenience on it!
Rex Hickey
Rex Hickey
I was able to publish it here, although I am uncertain why I could not get it to publish within this one. https://www.inventables.com/projects/tictac-toe-power-hour
Rex Hickey
David Merchant
HI REX, I LIKED YOUR DESIGN AND MADE ONE FOR MY GRAND KIDS BUT THE X DOES NOT FIT DO YOU KNOW WHAT I DID WRONG
David Merchant
Kristina Ash
X and O does not fit, file needs compete rework.
Kristina Ash
Rex Hickey
The x points need to be sanded once off of the machine because they pocket is rounded. Tolerances are tight so parts may need a slight bit of sanding to fit correctly
Rex Hickey
