Toothpaste Squeezer
56 opens
35 copies
John Kalbac
John Kalbac
Simple wooden toothpaste squeezer. Approximate size is 3″×3″ with a 2.5" opening to accommodate most tubes. The opening is .125", which seems to give a good squeeze ratio.
Super quick cut; roughly 10 minutes on a Shapeoko 3.
Carve 1
Outline and through-cut with a .125" bit. Adjust the model if you want to add tabs for a full cut-out.
Carve 2
Optionally perform the detail cut with a v-bit. I used a 60* with good results.
