Travel Pencil Case
250 opens
24 copies
709 downloads 0 comments
Beyond Design
Beyond Design
Chicago, Illinois
A simple case designed to utilize the flexible properties of polypropylene. The Design itself is very simple, with plenty of room for engraving and customization.
Black HDPE Sheet
Black HDPE Sheet
Thickness: 1/2 in don't use, Dimensions: 8 in × 12 in don't use
Polypropylene Sheet
Polypropylene Sheet
$4.20
$4.20
pencil case poly pro.svg
pencil case cap.svg
Mill Polypropylene sheet
Use a 1/16" endmill to mill the channels for folding as well as the overall profile. Polypropylene is the ideal material as it will bend without cracking or breaking.
Use this EASEL link
Mill End Caps
Use a 1/8" endmill to cut your cap pieces. I used 1/2" red HDPE for its bright color and durability, but this could be any material that is tough enough to hold the polypropylene in shape. Choose whatever color/material you like best.
Use this EASEL link
Assembly
Start the folds in the polypropylene by hand. If the material is too stiff you can use clamps to squeeze and hold it in shape while you put on the endcaps. Remove the clamps and the material will expand to hold the endcaps securely on. No glue is needed, although you can certainly add some for an even more secure fit.
