Trivet - Death Star
1021 opens
444 copies
16 comments
Fernando Romero
Fernando Romero
Death Star inspired trivet out of hard maple
Preparing the Easel files
With the latest Easel enhancements, all of the different operations are contained in different "work pieces".
Work piece one: contains the tool path to cut the texture on the surface of the deathstar. Work piece two: contains the tool path to cut out some of the unfinished sections of the deathstar. Work piece three: contains the tool path to cut out the deeper section of the unfinished deathstar and the outline. Work piece four: contains the tool path to cut the spherical scoop on the face of the deathstar. (Using an external gcode sender is no longer required).
Estimated time: 30 minutes
Final Product
Sand and finish.
Bob Jewell
Please share the files for the rest of the project. Will not open in Easel.
Bob Jewell
Jean-Baptiste MUTIN
Hello. Which software do you use to control x-carve? Thanks.
Jean-Baptiste MUTIN
Fernando Romero
At the time i made this trivet i used two programs: 1) Easel for the flat (2D) milling and 2) Meshcam to generate the 3D path for the dish and Universal GCode Sender to control the cnc.
Fernando Romero
Philip Storm
I tried to open in easel and it says project not publicly shared.
Philip Storm
Fernando Romero
Philip, I've created a new Easel file now that the program has better capabilities and attached that to the project. Let me know if it works.
Fernando Romero
John Smith
Fernando, ho do I get the Easel File? I don't see it in the zip file and the easel project link does not open.
John Smith
John Horgan
I only see the file for the scoop, don't see the other three
John Horgan
Fernando Romero
I just added a zip file that contains all workpieces
Fernando Romero
Fernando Romero
I also just saw that there is a "share option" on the file menu and I selected to make the easel project public. I hope it works now.
Fernando Romero
Philip Storm
Fernando, everything worked out perfectly. Thanks for sharing!
Philip Storm
Wally
there is a zip file but i dont know how to make it do the other 3 files. only gives me the first
Wally
David McGrew
Fernando - Just downloaded, and I will start tomorrow. Thanks. Looks great!
David McGrew
Gerald Runion
Any idea how I would scale all workpieces such that I could cut this out of a 6.5"x6.5" piece of wood other than the 9x9 used here?
Gerald Runion
Fernando Romero
The "flat" geometry you can scale by selecting all (CTRL+A) and then going to the size tool, locking the proportions and entering a new dimension of 6.5" The "Scoop" gcode, I generated outside of easel. I can scale it down later tonight and place it on the project file.
Fernando Romero
Gerald Runion
thank you
Gerald Runion
Charles Daily
Fernando, thanks for this. A couple of questions 1. Why multiple workspaces, seems like the same bit used for all carves? 2. Why on the scoop is it not starting at 0/0?
Charles Daily
