VCarved Sugar Skull
1544 opens
662 copies
9 comments
Kyle Russell
Kyle Russell
Simple VCarved sugar skull that you can make as fancy or plain as you want!
I spray painted the surface to get color in the grooves and sanded it down to bring the wood color back to the surface. I also sanded down the edges to create the weathered look on the sides.
Carbide V-Bits
Carbide V-Bits
$15.91
Cherry Wood
Cherry Wood
6" × 12" × 3/4" Cherry Wood
$10.86
$8.49
Add to Cart
$35.26
James Brewer
It's not shared, would love to make one of these?????
James Brewer
Manuel Bernal
You can find the original file posted by me 4 months ago here http://easel.inventables.com/projects/HcIdBuVNoTY2RUwugnLZ-A
Manuel Bernal
Sean Morrish
Do you have an svg file for it? or something with an outline separate, so the machine can cut all the way through on the perimeter? I don't have a scroll saw, or band saw.
Sean Morrish
Sean Morrish
Scratch that last request. Got it sorted with the offsetter feature app.
Sean Morrish
Chris Maloney
I did everything per the design and I did not change a thing. It did not cut out the design with the 60° bit.
Chris Maloney
Chris Maloney
Edit: It did not carve out the complete design with the 60° bit.
Chris Maloney
chris raley
Can you provide photos of this piece in work or from other angles? I have lots of questions.
chris raley
David Peterson
Thank you for the design.
David Peterson
Brandon Fryman
This seems like a really deep cut at 11 mm is this accurate?
Brandon Fryman
