Walnut Roman Clock
41 opens
7 copies
Martin Ball
Martin Ball
A simple but elegant looking clock face made from walnut with roman numeral characters.
Birch Plywood
Birch Plywood
6" × 12" × 3/4" Walnut
$11.43
$11.43
Plywood Key Inlay
First mill the plywood key inlay which will be used to mount the clock on the wall.
Negative Inlay Cutting
On the rear of the walnut piece mill the inlay section for the plywood key.
Front Carving
Flip the walnut piece over and insert a 60 degree V carving bit and carve the front.
