I had this idea of creating a wood joint with a wavy shape and ended making a top for a small table. I think it is a pretty cool way to explore the mixing of two different wood species!
** The author's moral rights;
This is the making of this side table and hopefully you can find some inspiration to create your own designs!
I love this small table. I think I just might make a couple of these.
Tracy Ranson · June 23, 2018
I have a lot to learn yet. I'm working on a battery powered led lamp for my sister and was trying to use your wavy table ( but it will be circular when finished) but my cnc only cuts 18" max in X.
Greg Purl · October 19, 2019
I played with the Gcode and was able to reduce the length to 13", but the parts don't quite mesh. When I reduce the length of the Svg in Gimp, upload to easel, it says there are embedded images. Any hints for a newbie?
I think I just realized my problem with the cutting. I used a 1/8" bit instead of 1/4" you have in your program.
I tried to put the curves together, they never may match, please explain how that should be done. TY!
Matthias · December 26, 2020
