Wooden Pie Boxes
1796 opens
748 copies
8 comments
Katie Cleveland
Katie Cleveland
Learn how to create these beautiful pie boxes using the box generator app and the X-Carve
Baltic Birch Plywood
Baltic Birch Plywood (×2)
18" × 24" × 1/4" Baltic Birch Plywood
$5.99
Carbide V-Bits
Carbide V-Bits
$15.77
$21.76
How To Build A Wooden Pie Box
Learn how to modify the box generator app to make these wooden pie boxes. You can find the video tutorial on how to modify the box generator and create more space between the top of the box and the lid here: https://youtu.be/fy9pIJDPOeM
Get the full step-by-step tutorial on how to build the pie box on my site, Addicted2DIY.com: https://addicted2diy.com/2017/10/30/diy-wooden-pie-boxes/
Brenda Steadham
what feed and speed did you use for the 90 degree v-bit for the lettering?
Brenda Steadham
Brittney Naylor
hi, i have tried cutting this twice & they dont slot together. the tabs are all the exact same size which causes it to just hit. is there something i am missing
Brittney Naylor
Don Kuehn
When using the box maker app, make sure that you measure your bit's actual cutting diameter and the material thickness, then set those in the project BEFORE you generate the pieces.
Don Kuehn
Jason Leonard
Is this file public?
Jason Leonard
johnny
This basic box in Inventables and this can be used commercially.
johnny
Rudy Aiello
So the file you have on here does that have all the fixes on it? Or does the file need modified so the lid will fit
Rudy Aiello
Martey Guidry
Do you share the g code?
Martey Guidry
dustinbank
This box design is amazing. https://www.cpfoodboxes.com/product/pie-boxes/
dustinbank
