Wooden Wall Outlet Cover
500 opens
254 copies
1 comment
Lawton S
Lawton S
Whether you are in of a quick and inexpensive wall outlet cover, or looking to add some spice to a wall, this wall outlet cover does just that. Carving takes less than 20 minutes, and it fits any standard US wall outlet.
Making the chamfer
The first cut we will make creates the chamfer of the cover. This will be done using the 1/4" 60º V-Bit. It should pass through all but about 1/8" of wood, which will prevent it from being removed until the next step. Once the cut is done, swap the bit for a 1/8" standard wood bit.
Estimated time: 2 minutes
Carving the Sockets
This second (and last) cut we will make cuts the socket outlines, the screw hole, and at the end the perimeter. Be sure the bit is now 1/8" and it is beginning in the same position. This time, the perimeter cut should go all the way through the material
Estimated time: 13 minutes
Attaching the cover
Now that you're wall outlet is carved, we can attach it. Ensure you have switched power off for the outlet before you begin. Remove the current wall cover by unscrewing the flathead screw located between the two outlets, and screw the new cover on.
Estimated time: 5 minutes
Christian Gregory
Assuming you don’t need to carve anything off the back for the actual outlet to fit?
Christian Gregory
