Button Head Cap Screw |
Length: 8mm, Quantity: 10, Thread Size: M3 |
$2.49 |
Length: 12mm, Quantity: 10, Thread Size: M5 |
E-Stop Button |
Type: Latching pushbutton |
Panel Connector |
Pins: 2, Diameter: 16mm |
Panel Connector (×4) |
Pins: 4, Diameter: 16mm |
Power Entry Module |
Connector Type: IEC60320,, Mounting Style: Bolt Flange |
Pre-Assembly T-Slot Nuts Packs of 10 each |
Pre-Assembly T-Slot Nuts Packs of 10 each - 25281-05 (x10) |
USB Bulkhead Cables |
End 1: USB B Female (Bulkhead), End 2: USB B Male (Cable), Length (approx): 30cm |
$2.49 |
Using 3mm aluminum cut the front and back.
The engraving of the X-Carve loge was done to a depth of 0.5mm. The small letters was engraved to 0.3mm depth.
Bits used are:
3mm, 2 flute upcut designed for aluminum
2mm, 2 flute upcut designed for aluminum
60 dg V-bit
Use ethanol as coolant
180 minutes
Cut the side profiles 300mm long and cut M5 threads
Cut top and bottom plates 300×260mm
Mill the top plate fan hole using 1/8 in upcut bit.
Drill the top/bottom plate mounting holes.
Assemble the box. Remember to put the T-nuts in to the slots before closing the ends with the front/back plate.
Mount PSU, Arduino, connectors and relay
Connect all wires
Test that all works again.
Christopher McCoy
Todd Neale
Martin Barfoed
Russell Holt
John Hunter
Martin Barfoed
John Hunter
Steve Knop
Martin Barfoed
Domenick Salvemini
Martin Barfoed
Tony Lehto
Martin Barfoed
Martin Barfoed
Martin Barfoed
Tony Lehto
Isaac Neuman
Chris Byrne
Chris Byrne
Martin Barfoed
Chris Byrne
Isaac Neuman
Martin Barfoed
Martin Barfoed
Isaac Neuman
Isaac Neuman
Martin Barfoed
Martin Barfoed
Martin Barfoed
Martin Barfoed
Isaac Neuman
Angel Ars
Martin Barfoed
Martin Barfoed
Martin Barfoed
ivan palomo
Eric Mogensen
Martin Barfoed
hannozero
Martin Barfoed
lee fletcher
Martin Barfoed
