XPS Foam Snowmen
6 opens
0 copies
Gregory Wurst
Gregory Wurst
Inspired by XPS foam gravestone projects here, I made these snowpeople out of 16″ × 24″ pieces of XPS foam. I made a snowman, snowwoman, and snowkid – which are posted here separately.
Cut, paint, and mount.
I mounted the foam to the X-Carve Pro wasteboard using double-sided tape. For ease of cutting I separated the cuts into 2 projects, but they are combined here. An 1/8" upcut bit is used to cut the outline and a 1/16" tapered bit for a light pass to add detail and make it easier to paint the details.
A piece of 1/2" PVC pipe is glued to the back using construction adhesive and then a piece or rebar is hammered into the ground to hold them. I painted the entire thing in a couple coats of white stain-sealing primer and then painted the other colors on top.
Snowwoman – https://easel.inventables.com/projects/QDzZ25tLXwozEaM971qiFw
Snowkid – https://easel.inventables.com/projects/s-s9sX3m9q-pj-4QL24HZQ
