Black MDF Sheet
Strong, organically dyed wood fiber panels
Black MDF Sheet
$15.20 12 in × 12 in 1/4 in
$11.34 8 in × 12 in 1/4 in.
Features
  • Easy to machine
  • Non-toxic
  • Perfect for Halloween!
Cut tolerance
+/- 1/16"
Color
Black
Thickness
1/4 in
Type
MDF
Files & Attachments
Data Sheet
forescolor_technical_data_sheet.pdf
Q & A
Ask a question about Black MDF Sheet
Christian W Zagarskas
Need this in 24x24
1 answer
fab
Is Forescolor the same material than Valchromat ? Can I use this material for kitchen island countertop?
1 answer
fab
materials@nervo.us
Is this product suitable for lasercutting?
Is this product safe to lasercut?
1 answer
Marko Berkes
I am interested in using Valchromat black mdf in a furniture project. Would you please suggest correct finnishing applications?
Or can it be used without any colours applied? I am planning to use it in areas where moisture is present and also dry areas. thank you in advance 1 answer
