Post-Assembly T-Slot Nuts
Post-assembly insertion nuts are used to fasten objects to standard 5 series aluminum extrusions (including makerslide). These nuts are used in conjunction with a fastener such as a socket head cap screw and a flat washer. Simply insert the nut into the extrusion from anywhere along the exposed slot.
Made from Low Carbon Steel with a Trivalent Chromate surface finish.
- Insertion Type: Post Assembly
- Qty: 10 pack
- Type: Insertion Nut
