Silver Glitter Acrylic Sheet
Silver sparkles add depth as light reflects off the surface
  • Silver Glitter Acrylic Sheet
$40.16 12 in × 24 in 1/8 in
This product is out of stock.
Sign up to be notified when it's available.
This striking sheet contains silver specs of glitter. It can be laser cut and milled.
Due to the manufacturing process, the sheet’s surface may not be entirely smooth – there can be divots. The concentration of glitter also varies by batch, with some sheets having very dense glitter and some sheets having a more sparse glitter pattern. This is an unavoidable part of the manufacturing process.
Color
Silver
Effect
Glitter
Opacity
Translucent
Surface Finish
Glossy
Thickness
1/8 in
Thickness Tolerance
± .05 in
Q & A
Ask a question about Silver Glitter Acrylic Sheet
Joe Parker
What bit would you use to mill/cut out ornaments?
Using a Sainsmart 3018 pro -
1 answer
Joan Lee
I am interested in buying two panels sized at 28 in x 26 in. Is the Silver Glitter Acrylic Sheet available in this size and if so, what is the pricing on that?
1 answer
