X-Carve CNC Machine Style NEMA 23 Stepper Motor Kits
These NEMA 23 motors run the three axes on your machine. The pulleys come attached to the axes. Snap-in wiring makes it easy to set up your machine, even if you aren’t comfortable with electric assemblies.
Includes:
• Four (4) stepper motors with attached pulleys
• Four (4) cable assemblies
Does Not Include:
• Mounting Hardware
This hardware is included in X-Carve Core Components kit or for purchase separately
- Step 1 (1000mm):: "1000mm assembly instructions":http://x-carve-instructions.inventables.com/1000mm/step2a/5motors/
- Step 1 (750mm): : "750mm assembly instructions":http://x-carve-instructions.inventables.com/750mm/step2a/5motors/
- Step 1 (500mm): : "500mm assembly instructions":http://x-carve-instructions.inventables.com/500mm/step2a/5motors/
- Step 2 (all sizes): "X-Carriage":http://x-carve-instructions.inventables.com/1000mm/step2b/5motors/
- Step 3 (all sizes): "Z-Axis":http://x-carve-instructions.inventables.com/1000mm/step2c/10homeswitch/
- Step 4 (all sizes): "Belting":http://x-carve-instructions.inventables.com/1000mm/step4/
- Step 5 (all sizes): : "Wiring":http://x-carve-instructions.inventables.com/1000mm/step6/
