SWAT Eagle Sign
83 opens
42 copies
3 comments
Block Cop
Block Cop
Indiana
I designed this sign for my fellow SWAT operators. This is made from Solid Red Oak. I utilized the ribbon from the “Pro Design Library” to add the name ribbon on top and bottom. I used the “Shapes Tool” to add the circle and other background. The Image of the SWAT Emblem was purchased off Etsy.
1. Prepare Wood
Use Red Oak board cut to size:
22″ × 29.5″×.75″
(Glue up several pieces if necessary)
Sand to 220 Grit
Raise the grain (spray with thin coat of water)
Sand again to 220 Grit
Add Oramask Vinyl to Front Side
2. Carve "2 Stage Carve"
480 minutes
Rough Pass – 1/8" End Mill
Feed Rate: 46.8 in/min
Plunge Rate: 9 in/min
Depth Per Pass: 0.0625 in
Detail Bit – 60 Degree V-Bit
Feed Rate: 52 in/min
3. Carve outer shape
26 minutes
Cut out using: 1/8" End Mill
4. Key Holes
Flip piece and add Key Holes in Back
Use Key Hole Bit: 3/8" Diameter
5. Clean Up
Clean up using sand paper (220 Grit) and small carving tools
Be sure to tape around edge if you don’t want it painted.
6. Pre-Seal
3 coats on front prior to painting:
I use the following:
Minwax – Waterbased – Polycrylic – Clear Satin
(30 minutes between coats)
7. Paint
1 – 2 coats of spray paint:
Rust Oleum – 2x Ultra Cover – Paint & Primer – Satin Canyon Black
8. Round over edge
Route outer edge with 1/4" round over bit
9
9. Peel off Oramask
Peal off Oramask (using small Exacto knife if needed.)
10
10. Finish Sanding
Sand exposed wood front and back
Using 220 grit
11
11. Clean before sealing
Blow off dust
Wipe down with damp micro-fiber rag
12
12. Seal with Polycrylic
3 coats front and back
13
13. FINISHED!
Let dry and you are done!
Glenn Watson
Are you willing to make one for a different agency ? If so, what would you charge ?? Gwatson@hallcounty.org
Glenn Watson
Walter K Hurd
I want to learn how to design one. HELP!!
Walter K Hurd
Block Cop
Do you have an email?
Block Cop
