Grey MDF Sheet
Strong, organically dyed wood fiber panels - On Sale!
Grey MDF Sheet
$11.11 8 in × 12 in 0.2 in
Features
  • Easy to machine
  • Non-toxic
Cut tolerance
+/- 1/16"
Color
Grey
Thickness
.2"
Type
MDF
Files & Attachments
Data Sheet
Colored MDF Data Sheet.pdf
Q & A
Ask a question about Grey MDF Sheet
Joshua Mosley
Pease update the actual thickness - it is less than 1/4"
1 answer
Raymonde Bieler
Is is possible to order a sample of the product ?
1 answer
Richard Smith
Is it safe to laser cut this material?
1 answer
Chris A
Can I buy larger size sheets?
1 answer
